FSE Power Boost Valve
Now as I understand it your standard Injectors max out at about 15 PSI.
Replacing your injectors to 555 or higher is not exactly cheap, has any body used one of the above items to up the fuel pressure therefore giving more fuel delivery ?????
I have - did it about 2 weeks ago. I'm running 1.4 bar on bigger turbos and everything seems fine so far (although I think I'm running rich off boost - good for flames:D )
Adam,
Where did you buy it from
I got mine from DP motorsport in Warrington. They do mail order - you can phone them on 01925 445174 or check out their website on http://www.dpmotorsport.com
hope this helps
Adam
Cheers mate just spoken to them
