High tickover
Hi all
i posted a problem on the old forum about 12 months ago about high tickover speed and can remember some thing about the T.P.S i think that was it!!! it worked on my last z but doesnt appear to on this one [wriggling wires etc] is there other things i need to look for?.
cheers
Dave
Basically clean everything.
Water temp sensor,
change air filters,
fuel filter,
clean TPS,
and reset ECU.
I had a high tickover and after I changed the filters and cleaned the sensors it went, as did the irratic idle.
Stuart
I cleand my TPS ( i think ) the other day, that little black box on the side of the passenger side throttle body, as my tickover was a little uneven, when i put it back it ticked over at 2,000 revs until i realised you turn it with the screws loose to your desired tickover and now she purrs on tickover at a sweet bit below 1,000 revs.
So if yours is too high, a twist of this TPS thingy should sort it.
Good luck.
