stereo wires
just doing a de-briefing on my ice install think i have got the jiste of it only got one question before i tackle it
what is the accesories red wire and where does it go on the unit can't see it mentioned in the destructions
sony ca430x unit
10 disc changer
no amp cause i don't know much about them, what difference in sound do they make???
ps anything i should no before i rip everything apart
cheers Andy
forgot to say what is the wire for dohh:o :o
Andy -
One thing to watch: Be very careful when getting to the head unit. The spring clips that hold in the metal strip on the centre console have a habit of falling into the dark recesses of the car, never to be found again. Also on my motor at least, the plastic is a little brittle and can crack and split.
One more thing - you'll probably put your car into reverse or second gear to move the stick back a bit. Remember to stick it back in neutral when you're done!!
Good luck!
Russ.
is the red wire from the head unit or the car?
I had trouble when fitting mine, i couldn't find an earth in the connector block, i found a earth tab down in the bottom left side of the space where the unit goes and used that one.
