REC button
Hi all manual tt owners.. can anyone tell me in what situation would you press on the REC button beside the ECON button.. I notice the revs do change slightly..
Thanks..:)
It's for the Black Box Flight Recorder which is fitted underneath the spare wheel.
.. I've played the recorder over n over... all it says is VRROOOOMM...VRROOOOMMM...
nice pics on your RIDES..
Monzee,
I believe it's for Reciculating the air inside your car, rather than drawing the air from outside.;)
Cheers,
F.T.
'Air recirculate switch
ย
Push the REC switch to recirculate interior air inside the vehicle. The indicator light will come on.
ย
Push it again to draw outside air into the passenger compartment. the indicator will go out.
ย
* The air circulate switch will activate only when the AUTO switch and air conditioner compressor are on.'
ย
Above is from the Owners's manual.
ย
There are so many 'What does this button do?' questions recently that it might just be worth PDFing the whole of the Owner's manual!
ย
Tim
Or do something radical like I did after I bought my Z...I bought an owners manual!!:eek: :eek:
Cheers,
F.T.:D :D
If you dropped one and want to savour the aroma a little longer then rec will recycle it for you. At the same time it will restart your compressor to chill and dehumidify it as well if the AC was set at Econ beforehand! Hence the change in revs.
:D :D :D LMAO
ย
I like it............
ย
ย
"Hi all manual tt owners.. ".............you're right, those "auto" boys aren't worth talking to! LOL:D
Thanks guys.. now i know when 2 press the button if any passenger should deserve my nuclear test...:D
Don't use it if you had a vindaloo the night before :)
ย
Back to the gutter when bored at work !!!!!!!!!!!!!!!!!!!!
