Right, I'm getting my first test drive today...
- Replies 33
- Views 1.6k
- Created
- Last Reply
beermonster 2 posts
shaunmac 1 post
russtic 1 post
jaffa 1 post
And I need to know what to expect, so I can hopefully have and idea if this Zed is healthy or not...
1)
What's the power delivery like?
In my previous cars I went from an 8v to a 16v and I thought the 16v was broken at first till I hit 5000rpm then it goes mad.
What's the power curve like on a Zed TT, when do the turbos start to boost and what at what speeds does it go best?
Do you get a kick and get pinned back into the seat, or is it a smooth building power delivery?
2)
I know to check the boost gauge actually goes into the right hand side when giving it some, what should the other gauges be showing ie. Water temp, oil temp? pressure? etc..
3)
Handling
I've heard the back end of these cars can kick out due to HICAS, how noticable is it and does it scare you the first time it happens? ;)
Also do they tend to understeer or do they like to oversteer?
I know about the power on oversteer (any one with a brain knows a RWD with lots of power may try to swap ends in the wet.) But do you get a warning before it goes, or is it facing one way then the next second facing the other way?
Do you have to be "really" silly in the wet to do it, or is it very easy to do?
4)
Auto box
Yes it's the auto questions again ;)
The autobox on my granny was pretty jerky on gear changes and would lurch from one gear to the next, whereas a Merc I went in was so smooth you couldn't even feel the gearchanges.
What's the Zed's autobox supposed to be like?
If the UK car doesn't have a power button does it have kickdown?
Sorry for all the questions but I need to know what to expect when I look at this car in a couple of hours :)
