Finally put the dash back together today, was testing out all the buttons etc.. Theres a problem with the fog lights. I press the button and sometimes the lights only come on very dim, like so dim when i put the sidelights on it gets brighter ;)
Bout half the time they come on normal, the rest they come on dim. Likely to be a problem with the switch or the relay? Anyone else had this problem?
CheerZ :)
You probably have a bad earth some where check all earth wires
all the best Sid
fixed it, was a problem with the relay, i gave it a tap and now its working fine :confused: :D
