just recently whenever i go over a bump, and in the zed a 5 pound note feels like a bump, the open door warning light flashes in time to the bump, sounds like a loose connector as it sounds like i can hear a solenoid click, or it could just be another rattle coinciding with the bump were would i find the sensor to check it out.
thanks in advance
rob
The click you are hearing is the the trigger relay for the open door light, it could be a faulty switch on the rear boot (inside the lock) or a cable fault at the same place, the interior light would come on if it was a door pin problem.
Jeff TT
Mine did that. Just needed the door adjusting slightly.Worked for me:)
Mmmmmmmmmm - my interior light used to come on on hard cornering - I fixed it by adding a rubber mount (something like rubber feet from a stereo or similar) directly in line on the door!
I got mine from Homebase - self adhesive rubber feet section!
AndyGP
im gonna try get it down to jeffs for a 60k service and a few other bits n bobs, i just turn the music up now and dont notice
