Heavy Clutch problem!
MY Clutch pedal seems to go VERY heavy intermittently.
I'm guessing its a Hydraulic thing...
Anyone have any ideas?
Dan
Surely im not the only one with this problem??
Dan
what clutch set are u using? Racing clutch tends to be hard..
Standard setup.
Its been fine but the last couple of days its been hard to push...
I noticed it before if ive tried to push it when the engine isnt started but its been ok once its running.
Now it seems to do it intermittently whne im driving...
I can usually make it work better by pumping the brake pedal!!!
Dan
Checked your clutch fluid of late?
Nope....
How do i do that?
Im assuming the clutch doesnt have a booster, but if it does it'd be that leaking probably:D
Couldnt see the booster and the fluid is not low...
Im guessing theres air in the system, how does it bleed? is it the valve near the power steering pump?
Dan
The clutch has a booster and it could be leaking
or the hoses to it.
I would check the manual .
That explains why its hard when the engine is
not running.
I checked the manual and it appears that the booster is next to the ABS unit, but i cant see it there!!!
Help.......................................
yup - these baby's have servo assisted clutches. check the servo & pipes
