OEM Brake calipers - aluminium vs cast iron
As per the "what did you do" thread I had to source a pair of replacement front calipers today, as mine have seized on the lower inner piston on both sides.
After searching the 'net, I found a couple suppliers had them in stock. First being Torquen - albeit at over £600 for a pair for either cast iron or aluminium.. Then I found some fully rebuilt aluminium ones (the correct fitting for a TT) at less than half that, which got me thinking. Cast iron vs aluminium....??
Both seem to have their merits and drawbacks - the ali ones being much lighter, so less unsprung weight - whereas the iron ones allegedly handle the heat better, reducing the chance of disc warpage. If one believes everything one reads on the interweb LOL!
Seeing as I don't track the Zed - and I am happy with the OEM set-up, when it works properly, plus I have a set of Brembo discs waiting to go on, as opposed to the Ebay ones I had previously, I thought the ali calipers would suffice.
Opinions please - good or bad😁
Both the aluminuim & steel calipers suffer with piston issues.I rebuild them at work & would have done yours Richard if you had asked.A few hours is all it takes & a kit is about £60.I think Nissan used cast iron as a money saver only & not because of any benefits personally.Brembo discs here are made by Euro Car parts & are not the Brembo quality being honest.I would say they are no better than M tec that awful E bay brand.I use Blueprint discs for stock set up,s.I would try those .
Thanks Jim. Great heads-up on the discs - I stopped using M tec a while ago as they just didn't last a year without warping. And I would definitely have come down to yours earlier, had I known about the caliper issue!
