No spark, No fuel injectors firing .
we also are not getting the fuel injectors to activate. However, the fuel pump is working.
My 1993 Z 32 was running fine and I turned the engine off and went to start again and it would not start. We have replaced the crank angle sensor with a with a used one and also tested it and it appears to be working. The fuel pump is working. The TPU also appears to be working when doing a bench test. we checked the the ECU and red error code 11 and 13, or refers to the crank angle sensor circuit and cylinder head temperature circuit.
I get a 5v reading out of the CAS then gets interrupted when spun by hand, but the injectors are not firing. I has 12v to the coil packs aswell. So in my opinion it leaves the ECU, can it be diagnosed any other way? Thank you for any help.
No posts to show
