N/A ecu chip
Hi, new to the Z32's, where woukd be the best place to get a chip for my 1996 N/A? UK obviously, cheers
Hi fella,Unless you swap the ecu out for an earlier 8bit unit you will not be able to chip it.If you can sort an ecu (pre 95 ) i can install a socket & chip for you.Or we could convert the car to a twin turbo model instead ☺️
Ok, sounds good. I'm building a rally car, so turbo is not an option. Do you know roughly how much bhp gain Iwould get from ecu chip,exhaust headers and exhaust, I am also going to put lightened flywheel, billet crank pulley and one piece propshaft. Don't suppose throttle bodies would be worth it at this stage?
Stage 2 ......would be cams and throttle bodies.
What do you think?
