MOT fail
My zed had a failed MOT on Thursday
Under Major Defects! - seat belt anchorage prescribed area strength or continuity significantly reduced
Nearside Front (floor pan) MOT report.
My problem is this ! My seatbelt anchorage is not on the floorpan!
So, I took the front Nearside seat out which is good 👍
What advice can you give?
Arthur
So has the anchorage become corroded or detached itself somehow - and has it happened since your last MOT?
I can see your logic in removing the passenger seat though - no seat = no need for seat belt🤣
I presume it's a matter of some welding, do you have pics to share?
Hi all, yes went back to tester for some clarification.
Took it to my car repair specialist who took the carpet up.
It appears the foot pan has 4 anchorage points for the seat.
& they need welding
My carpet was wet - it had rained heavy the night before, it has been in the garage for the past couple of months.
I’m thinking my targa drain has shrunk & come away from the outlet which I will check when I get the Z back.
This could be the reason of my floor pan issues.
