Power steering failure/leak!!!!!
Hi all
just brought another z this time a uk manual [phase2]
only had since weekend and on the way to work this morning
i popped into a shop and when a got back into the car i noticed the HICAS light wouldnt go out, when i tried to reverse out of the space i relised i had no power steering! and there was a large pool of fluid underneath!! can any one help.
I opened the bonnet and noticed a lot of fluid around top of reservoir but coudnt see any loose pipes.
cheers
Dave
Forgot to ask what is the best fluid to use as and when she is sorted
cheers
Dave
You need to use automatic transmission fluid in it. The best thing to do is jack it up and chock the wheels that are on the ground and put axel stands under the car, never get under the car when just supported by the jack my sound obvious but some people do it. Take off plastic under try, start car and get someone to tern steering from lock to lock you shod then see where the oil is coming from.
All the best Sid
Power steering system tends to leak at the connection below the resevoir a little but if a big loss of fluid in one go it is almost certainly the main high pressure hose from the pump to the rack.
ย
This liitle beauty is over ยฃ100 at Nissan however if you remove it and find a local hydrolic hose company they can replace the hose using the end fittings from the original and expect to pay around ยฃ25 to ยฃ35. Best fluid Dextron 111
ย
Jeff TT
