Tailgate Lock Dimensions
Does anyone know what the internal dimensions are of the tailgate lock barrel? I'm considering fitting a reverse cam in there.
I do have a link to a camera which I know another owner has installed successfully but unfortunately the listing doesn't mention it's dimensions. I'm hoping to find one with Night Vision and perhaps HD too.
I fitted a camera instead of the lock barrel. It fitted perfectly, then I refitted the centre pannel and it was like looking through a toilet roll. Had to bodge a spacer to Make it work
[sIGPIC][/sIGPIC]
Did you know what dimension the camera had to be or was it trial and error / luck?
I think some luck was involved
[sIGPIC][/sIGPIC]
The external opening in the reverse light panel is a fraction over 12mm.
So you’ll need it to enter through this/sit flush or else the degrees of sight will be compromised.
Thanks. Having not taken the panel apart / off yet my assumption was that I would present the camera from behind the panel and have it sit flush with the outside edge. I'm going to be ordering a couple of different cameras and will need to trial and error fit them.
Edited by sumshiftyguy
I have thought of putting a reversing camera there too - inspired by a conversation I had with Ian some some time ago......!
It's either in the tailgate lock hole or find a way to insert it into one of the reversing lamps. Tailgate hole seems the easiest - even if it's like looking through a toilet roll 😄
I have a camera which came with my Kenwood sat-nav head unit, wiring looks simple, but out of laziness, I just never fitted it at the time 😉
The annoying thing I'm finding is that all the bullet style cameras claim to be HD / night vision capable / etc but the reviews suggest otherwise. It looks a lot like pot luck.
So far I've not been able to find a HD camera that will fit so may need to go with a low-res one for the time being. Unless I can figure out another place to mount a larger camera. I don't really want to put holes in the bumper!
