Rear Bumper removal
Hi Is there link for a how too " rear bumper removal". I've tried a search, and Remember for my previous days years ago there was a link to everything on here so much so you could practically rebuild your whole car.
Graeme
TIA
Graeme
TIA
https://remont-bampera.com/en/nissan-300-zx
I searched for a guide and couldn't find it either. @JaiKai Do we have a guide floating around?
I have some notes below from when I took mine off:
Hopefully they make sense
1 - Remove Side Lights
2 - Remove Interior Panels
3 - Unscrew along the rear centre  = 11 nuts
    Along the left & right hand sides = 2 screws each in rubber washer-type things,
3 - Above rear licence plate along the top = 3 screws
4 - Underside behind License plate = 4 plastic screws in the middle + 1 in each corner
5 - Corners next to exhaust - 1 screw each side - Found these really tricky as they are exposed and may be covered in grit and dirt or even rusted out,
6 - Corners above exhaust holding the bumper to rear quarter panel = 1 screw each side
Just a few to find then. thank you  Its mire how to put one back on, but I figured there might be a guide on how to remove and just reverse it,
Thank you
