Hi folks,
I have just replaced the red "Z" badge on the front of my Zed, so if anyone wants the old one, you're welcome to it.
It has a stone-chip (hence why I bought a new one) and it came apart from the metal ring during removal. You'll need to glue it back together and source some adhesive backing to reinstall it (make sure you do it the right way round, the little "studs" are handed (one side it bigger than the other), to match the holes in your nose panel..... ?
Hiya, this still available? I’ve been looking for a red one!
#1. 1993 Twin Turbo Manual LWB in black (2022 - 2024)
#2. 1991 Twin Turbo Manual LWB in white (UK) 2025 -
Sure is Rob....
I think I still have your address - I'll post it to you mate. Might take a while to arrive, as the PO is apparently on strike ?
Thanks Richard!
 Let me know if you need anything, can I cover postage for you?
10 hours ago, Howl said:
Thanks Richard!
Now posted Rob.... And no charge mate, always happy to help our small community ?
Received! Think it’ll look great on a black car.
I take it that it’s just glued on with the two used to line it up right?
You're welcome, Rob!!
The red disc needs gluing to the silver base - and then you'll need a sticky adhesive pad to fix it to your nose panel. Some waterproof double-sided tape will suffice. Make sure that you check which way round the large and small tabs are, before you glue the disc in.... Otherwise, you could end up with an upside-down Zed logo ?
