Hks Afr....(s)?
HKS AFR controller £95.00
HKS S-AFR Fuel controller £275.00
Am I right in thinking the 1st one is air only and 2nd is air AND fuel?
Iain....what have you got?
Thanks,
SUPER AFR
PART # 4606-RA001
V. 010501
SUPER AFR OVERVIEW
The HKS Super AFR is the very first airflow meter correctional device in the industry with a built in CPU. The advantage of having a built in CPU is that instead of making corrections to the airflow meter voltage, the characteristics of each airflow meter is inputted in the CPU so it can calculate the accurate amount of air flowing in. Since the correction will be made to this specific intake volume, the correction ratio of fuel will be precise and proportionally correct. The Super AFR is compatible with most Import and Domestic 12V, 2~12cylinder vehicles that utilize a hot wire, Karmen Vortex, or pressure sensor. The internal CPU allows it to be versatile and be utilized on many of the newer type airflow meters. Also incorporated in the Super AFR is the ability of idle air/fuel ratio corrections as modification progress and require further specific tuning levels. The response function, similar to the one in the VPC, allows for adjustments to the fuel settings upon throttle inputs to improve driveability and performance. The EIDS function is automatically programmed with the data from the initial self-learning calibration and automatically activated to correct sudden imbalances is air/ratios from discharge valves upon deceleration.
James,I can't beleive the mid range torque this small electronic box has given me :D
I was gonna ask what a super AFRaaaaahhh was but didnt want to seem stupid:confused:
Anyway thats exactly what i thought it was;)
Or maybe an autobox friction reducer
