HYDRAULIC BRAKE PISTON RESTORATION PROCESS The next phase of the brake caliper restoration process involves inspecting and restoring the hydraulic brake pistons that were removed from both the front and rear brake calipers. The goal here is to put the pistons through one final cleaning process and then assess their restored condition to determine whether they can be reused or be replaced with brand new hydraulic pistons. https://i.postimg.cc/Mph2qvG8/1_All_Brake_Hydraulic_Pistons_2_(Before_Polishing).jpg (Above) The current condition of all the hydraulic pistons after undergoing a deep cleaning and de-rusting cycle in the ultrasonic cleaning machine. Before beginning the restoration work, I took a closer look at several areas of the pistons that still required additional cleaning. https://i.postimg.cc/P5BsTPqs/2_close_Up_Of_existing_rust_inside_pistons.jpg (Above) Rust deposits still remaining inside the inner barrel of the hydraulic pistons. (Below) Some staining or contamination present on the outer surface of the pistons. https://i.postimg.cc/9Qv5Crfh/2_Staining_or_marking_on_outer_surfaces_of_both_front_and_rear_pistons.jpg Grinding Process To tackle the remaining rust deposits first, I attached a small brass wire brush bit to my Dremel and carefully began grinding away the corrosion. This method proved to be very effective at removing the rust while leaving the underlying metal clean and shiny. https://i.postimg.cc/NjWqB50F/3_After_wire_wheeling_inner_barrels_of_all_brake_pistons_1.jpg (Above) Nearly all of the rust deposits have now been removed from the inner barrel surfaces, revealing clean metal underneath. https://i.postimg.cc/Mph2qvG7/3_After_wire_wheeling_inner_barrels_of_Front_brake_pistons_1.jpg (Above) The front brake caliper pistons came out looking great, with all rust removed. Only a couple of pistons still show minor pitting at the bottom of the inner barrel. (Below) The rear caliper pistons actually turned out even better than the fronts after the grinding process. https://i.postimg.cc/fbm4LD3V/3_After_wire_wheeling_inner_barrels_of_Rear_brake_pistons_1.jpg I’m very happy with how well the wire brushing process worked. The pistons have cleaned up so nicely that I’m now unsure whether I should paint the inner barrels or simply leave them as they are. What do you guys think — should I paint them or leave them bare? Polishing Process Next, I moved on to removing the staining or contamination that remained on the outer surfaces of the pistons. To do this, I set up my electric drill in a bench vice and attached a cone-shaped polishing wheel. This created a simple DIY polishing rig that made the process much easier to control. https://i.postimg.cc/wBLKvgtt/4_Polishing_Setup.jpg (Above) With this setup I can safely hold the piston while polishing, without having to manage both the drill and the part at the same time. This gives me much better control and allows me to polish the piston surfaces more effectively. Here’s the starting condition before polishing the first piston. https://i.postimg.cc/bvkXJpGg/4_Test_of_polishing_process_on_outer_surface_of_Brake_Piston_(Before).jpg (Above) It’s a little difficult to see in the photo, but there is a thin ring of staining along the upper section of the piston’s outer barrel. The goal is to remove as much of this contamination as possible using the polishing process. After about five minutes of polishing, the results were impressive. All of the staining on the outer barrel of the first piston was completely removed. https://i.postimg.cc/SKC0skXM/4_Test_of_polishing_process_on_outer_surface_of_Brake_Piston_(After_1).jpg https://i.postimg.cc/zfKmB8Lw/4_Test_of_polishing_process_on_outer_surface_of_Brake_Piston_(After_2).jpg (Above) As you can see, the contamination that was present on the piston surface has now been completely removed. All that remained was to repeat the process on the rest of the pistons. Just like the first one, the results were excellent. The polishing process removed all visible contamination from the outer surfaces, making the pistons look almost brand new again. https://i.postimg.cc/q7yfR4t1/5_All_Pistons_Polished.jpg (Above) The polishing process was quick, simple, and extremely effective. I’m very happy with the results so far. After successfully removing the rust deposits from the inner barrels of all the pistons and eliminating the contamination on the outer barrel surfaces, I am satisfied that these restored brake caliper hydraulic pistons are suitable for reuse. They can now be reinstalled into the front and rear brake calipers during the final stages of the restoration process.
DJ_Party_Favor · 14 hours ago 14 hr
Hey guys, a youtuber going by "Jesse's Garage" has been rating his subscribers 300ZX's and so to get some exposure of my Z and my 2kspec replica project, I sent Jesse in a few photos and some details about my Z and he then gave his honest opinion on what he thinks of my car and then giving it a grade of between F to A. It was a fun little exercise for me to participate in and I was differently excited to see my car finally posted on youtube. I am still editing my very first youtube video atm and it could be a little while before its ready to be pulished but I'm hopeful i can get it done sooner rather then later.
Here is the link to the video with my car featured in it, but he has done several videos with other owners cars which you can find in his channels playlists.
I was differently happy with his rating of my car (of course I would) and I hope it will show his audiance what a top teir 300ZX should look like in the future for other Z owners to admire and maybe strive for, which I think is the point of these types of videos showing what should be done to keep these cars looking their best for all of time.
