  1. Tap the 3-dot menu (ā‹®) in the top-right corner of the browser.
Oil Pressure?
Hope someone can help.Ā  When I start the engine from cold, oil pressure goes up to 4. When it is hot it goes down to 1 sometimes 2.
I think I have low oil pressure. Any advice appreciated.
Mine did that and is a very common complaint, no need to fear the worst.
I’d suggest a new oil sender unit and/or an aftermarket gauge.
The water temperature gauge is just as useless, that just sits in the middle no matter what ?.
As Andy says quite a common fault. Replace with a new sender. On RHD cars the sensor is located on the n/s of the engine block
(picture in link below) near the oil pan and looks like this:
https://conceptzperformance.com/wiki/index.php/Oil_Pressure_Sending_Unit
I recently bought one from these folks who were the cheapest I could find at the time:
https://www.importcarparts.co.uk/parts-info?id=10165
Edited by AndrewG
thanks for the link new sender arrived today, hopefullyĀ fit it this week
Good find Andrew - a fair bit cheaper than most other suppliers!!
