Air mix switch problem
I’ve got the later, manual air distribution controls, which now seem to be stuck on dash only. Ever since I had the car all positions have worked except full demist, which just clicked so I guess a rod is jammed or broken. But now I get no noise from the dash at all when I turn it.
As I had to take the pod off yesterday to replace a warning lamp bulb in the dash (Major PITA!) I suspect I’ve disturbed something in the switch or wiring (although to be honest I have no idea when I last moved the switch off demist/foot wells so it could have been toast for a while.
Does anybody have a pin out diagram for the HVAC connector on the back of the pod so I can test it before taking anything else apart? The only diagrams I can find are for the auto aircon pods. Also is there a specific fuse or relay for the mode control flaps? I can’t see one in any of the fuse boxes. The blower works fine so I know the connector is going home fully and both A/C fuses are good.
Thanks,
Chris
  • Replies 26
  • Views 5.7k
  • Scarecrow
    Scarecrow
    Holy thread resurrection Batman… But the motor is working again. It took me 3 hours on my back in the footwell, a USB endoscope and some moves that would impress a Pilates instructor, but I managed to
  • Scarecrow
    Scarecrow
    Well the “repair” lasted about a week before I got grinding of broken gears and a stuck actuator again. However after some Anglo Saxon and a bit of a search on eBay I found the mode control motor from
  • Scarecrow
    Scarecrow
    Job done! After disconnecting the control rod from the motor there was still no life so the gears are either totally jammed or it’s burnt out, so I didn’t bother trying to manoeuvre it out. Just left
Thanks Jimmer, glad to be able to give something back for all the great help and advice I’ve had from the forum (and from your good self)!
