Cheap injector replacement
Morning all
My UK manual 300zx is currently laid up due to two failed injectors. I’m looking for a cheap solution to get the car running again with a mind to trim the plenum so that I can replace these for upgraded 740cc when money allows.
I had thought to replace my duff injectors with used standard injectors but unfortunately my search hasn’t been successful. (I did manage to find someone who said they had a set of standard injector for £30 but they couldn’t find them in the end).
Does anyone know if the £100 for a set of 6 eBay jobs would hold up for a year or two?
Cheers,
Chris
1 hour ago, AndrewG said:
Have you asked Jim@PZ if he has any s/h 370cc ones? I would imagine that he might what with upgrades to larger sizes for customers.
Worth a try. Thanks Andrew. ?
You maybe be able to find some later style ones, as fitted to Skylines. They require an adapter kit but then you’ll need that for your 740s.
Ive a set in my garage that I meant to fit but in honesty probably won’t get round to.
Thanks for the idea Steven. I’ll be investing in a “95 loom with the 740cc when the time comes.
I would second Jimmer, will have some there, buying on ebay you are taking a chance.
I believe I have 1 new 370cc Jecs injector ur welcome to.
You would have to ask if it is ok to fit with ur other injectors.
Art
