June 24, 20206 yr Hi, I am looking to upgrade the front brakes on my 300ZX, without buying from America, does anybody know what conversions are available. I don't mind second hand. Any help greatly appreciated.
June 24, 20206 yr 350z front Brembos Callipers and discs. Virtually bolt on, cost effective and more than enough for road or light track use without being so large to negatively effect the front and rear bias. Readily available. That would be the good options. Skyline R33 Brembo. Very similar to above, there are some slight differences and they are more costly, scarcer and older. There’s various others, including Evo Brembos, K Sport, AP etc etc. All have various pros, cons and levels of expense.
June 24, 20206 yr 3 hours ago, Stephen said: 350z front Brembos Callipers and discs. Virtually bolt on, cost effective and more than enough for road or light track use without being so large to negatively effect the front and rear bias. Readily available. That would be the good options. Skyline R33 Brembo. Very similar to above, there are some slight differences and they are more costly, scarcer and older. There’s various others, including Evo Brembos, K Sport, AP etc etc. All have various pros, cons and levels of expense. All I had to do when fitting my 350z front Brembos was enlarge the hole size for the studs in the hub. Unfortunately I can't tell you what sort of improvement they were over stock as the brakes were still shit after they were fitted, turned out I needed a new MC! But I'm very happy with the feel of them with a brake brace fitted as well. Personally I don't see any need in going bigger - unless you are tracking it and you need to worry about fade, you are limited by your tyre grip anyway.
