Hi guys
Got a problem with my offside front indicator not working.  My partner has tested various parts of it and found that the bulb is fine, the flasher unit is fine, but the problem lies within the section I've drawn round in red below. Anyone idea where I can get this bulb holder/cable from? Thanks in advance for any help.
And also here, a great big thanks to Jimmer at PowerZed for getting the car back on the road for me after local mechanics screwed it up and it was off the road for months. Now just frustrating that I can't legally drive it because of this indicator!
It shouldn't be too hard to trace the fault in that small loom with a multimeter. The bulb holder does come apart (I've done it)
if the fault is inside it and the grey plug can have it's pins checked for damage/corrosion. The wires can be patched.
This indicator for sale has the loom:
https://www.ebay.co.uk/itm/NISSAN-300ZX-Z32-Drivers-side-RH-indicator-light-import-spec/383432591726
Edited by AndrewG
Thanks for your help guys. We'll have a poke around inside it and let you know how we go.
Hi Salli,It is usually the wire where it earths onto the bulb holder.You can post it down if you like and i will fix it for you and get it sent back up.
Jimmer, you are a legend! My partner has done exactly as you suggested and it's working again! Thank you.
