Brakes
Before i took my 1990 JDM TT auto off the road 2018 the brakes were locking up big time under hard braking.I skidded 3 times and thought this scares the crap out of me!!!I have got uprated 350z discs,New pads,And bits and bobs from Concept Z to make them fit and hopefully in couple of months will dismantle and rebuild calipers,Use stainless steel lines and brakes will be better than before.Does anyone know if 1990 JDM came with ABS as obviously if this could be faulty i will pull ABS unit out and have it rebuilt or replaced.Cheers.
It did, it was a hydraulic system in the boot behind the driver under a plastic piece.
Some did, some didnt. Not sure why (unless anyone can shed some light on this?) My 1990 NA JDM had ABS, my 1990 red JDM TT doesn't and my new 1990 JDM NA (was a TT) doesnt. Was it an optional?
Weird - I thought all TTs came with ABS; whilst some NAs didn't....??
Unless mine have had the ABS removed at some point?
On 21/02/2020 at 17:37, surreyseagull666 said:
...if this could be faulty i will pull ABS unit out and have it rebuilt or replaced.
Before you do that, is the ABS control unit LED flashing to indicate a fault in the system?
300zx_1992_FSM BR-34.pdf
Hi Andrew sorry for delay.No i do not recall any flashing warning lights.The car has been off the road for about a year and a half now so when the new discs,Caliper rebuilds etc are done i will know more but i certainly recall no warning lights.
