Just changed cambelt, 1st cyl Tdc, all cam markers in right place and also crank marker, belt was put on with white lines all matching.
Question is when I rotate engine white marks on belt never come back as started!!
Do they ever re line up?
Every time I rotate, all camshaft and sprocket marks are ok.
Has anybody any idea on this!
Did you fit new tensioners ?
Sent from my SM-G977B using Tapatalk
Used existing tensioner , seemed to be working ok put bolt in it closed ok , opened up after couple of turns. It was about 3mm . I know it should be 4mm . But nothing jumped on sprockets.
Update , i turned engine 12 times and noted results,
After 4 turns I was 180 degrees out  counting 24 cogs
After 6 turns  18 cogs out
After 8 turns 12 cogs out
After10 turns  6 cogs out
Then on 12 turns 0 cogs out     back to beginning
So I am feeling safe to run engine now. Phew.
Big Thanks to those that replied.
