TK3 blue paint
Does anyone know where I can buy the TK3 blue paint from or is it likely that I’ll have to get it made up?
Cheers,
Chris.
I've had very good results with TK3 paint supplied by these folks:
http://www.paints4u.com/ProductDetails.aspx?productID=5423
The paint comes out of the nozzle in a thin vertical "band" and layers up beautifully. The TK3 colour match
(with the clear coat) was perfect.
Great, thanks Andrew. This is for the engine bay, do you just use the same TK3 paint code but ask for none matalic or does the bay have a different paint code?
As far as I'm aware the factory painted the engine bay with just the base coat. The P4U base coat dries to a rather dull
flat/satin finish. With the clear coat on it is a very good match to the rest of the car. I need to return your seats and other
stuff so I'll spray a sample for you to see and bring that with me.
Edited by AndrewG
