White Smoke
Hi, from exhaust coming out white smoke, (it's not because of weather). smoke star to come out few weeks s after spark plugs was changed. Could it be head gasket or problems with cooling system?
any ideas?
White smoke is not necessarily a cause for concern. If the car is running well - and you have no fluid (particularly coolant) loss - then I wouldn't worry.
If you start having to top up the radiator - and the car runs hotter than usual, then suspect the HG. Also, look for signs of coolant mixing with the oil or vice versa.... Take the car for a long, fast run and then see if it still smokes when you get home.
Or see if they have elected a new Pope. Zed are very clever ........
Sent from my SM-G977B using Tapatalk
