Indicators
My 300zx indicators have stopped working, I've had a mobile car electrician have a look. He found all light/bulbs were fine?????
Any one ever had this problem or could help point me in the right direction solving this.
I've had this problem. The screws holding the hazard switch weren't screwed on tight enough or maybe they were too tight, cant remember now but worth a try.
strange one all lights are working an all bulbs ok???? thought it might be some thing like the stick??? just frustrating cause I brought it to use
This is a common problem with the hazard switch not fully returning to its ‘off’ detent, which inhibits the indicators. It often doesn’t look like anything is wrong and just needs a slight wiggle back towards the driver.
It’s usually caused by the hazard switch mounting point inside the pod failing, causing the switch to track in and out at a slightly misaligned angle, getting stuck in its slot. It’s an easy fix with either a brand new pod or a repair kit.
