Maf advice
well car is idling like a dog could'nt find a vac leak so tool the maf of and it idles smooth at 750rpm so get the multimeter on the maf, its 0.39v on ignition and should be 0.8v if i've read that right and on idle its giving 1.28v which is well in the middle of 0.8v-1.5v so hmm any thoughts chaps ? or suggestions i've cleaned the connections theres no corrosion on any of them which i couldnt believe .... so still thinking the maf is maybe half dead :hammer:
If it is the maf and it usually is donโ€™t do what I did buy 3 second hand ones over the years just bite the bullet and buy a new one
And if you do need one - after following Jimmer's advice by checking as he says above - get to Z1, as they are currently on offer at $248
https://www.z1motorsports.com/intake-mas-and-hoses/nissan/new-oem-300zx-mass-air-flow-sensor-meter-mas-maf-p-1752.html
