Brake Servo Pipe and Breather Pipe
Afternoon,
Looks like my oil leak is just rocker cover gaskets :clap:
Replacing perished pipes while I'm at it - I'm looking for a couple.
Can someone point me in the right direction - where's best to get them - is there anywhere in the UK?
Any advice on other things while the top's off?
Thanks in advance
David
I need (pics below)...
(1) pipe from the brake servo.
(2) breather pipe from the rocker cover - at the right rear of the engine
You can find your brake booster hose at JP carparts in Japan.
http://jp-carparts.com/nissan/part_detail.php?maker=nissan&type=132&cartype=&fig=470*&part=4747140P01&page=1&img=470=%20001
Not cheap though!
That's fantastic thanks
Can anyone point me at sourcing the breather hose that comes off the back of the rocker cover. Thanks
Is it 11826 on here http://jp-carparts.com/nissan/partlist.php?maker=nissan&type=132&cartype=25&fig=118
Edited by davidlyall258
maybe found part
You can get that hose in silicone too which might last longer than the OEM rubber.
https://conceptzperformance.com/czp-11826-30p10-s-silicone-pcv-hose-rear-lh-nissan-300zx-90-96-z32_p_3936.php
If you get the brake booster hose from jp car parts, you may aswell sling the PCV hose on that order (if you don’t want the silicone one). You could probably order the PCV hose in the UK or from the usual companies in the US but that brake booster hose is NLA and JP seems to be the only place to source them that I know of currently, so you could make the most of the shipping cost!
