Injectors
Quick Question does it matter which way round the plus and the minus go on the injectors it just that some tit before me cut all the injector connectors off and replaced them with little individual connectors which keep falling off and touching each other etc.
anyway ordered some new ones from Courtesy and the plus which i presume would be the thicker of the two wires is the other way round on the connector so i have a thick plus wire going in to a thin plus wire on the connector and a thin minus wire going on to a thick minus wire on the connector
Confused:confused:
would this be ok or can i swap them over (thick to thick) (thin to thin)
sorry if this sounds a little confusing
No they'll be fine - its basically only a coil inside...
CheerZ,
Andy
Cheers Andy
Bagins / Andy it DOES matter which way around the wires go, since the injector is simply a solenoid. Put the voltage around the wrong way, and the pin will try moving the wrong direction inside the injector - releasing little or no fuel.
Si
p.s How's the motor coming on Dr Muff?
Erm yeah that could be a good point... DOH!!! :) Although if its working now I'd say don't swap it ;)
The motor is gonna be running soon now! Few more weeks then we're there... only on stock injectors for now though - just wanna drive the damn thing lol
CheerZ,
Andy
Now I am confused any ideas what current runs through the injectors ??
