Time to tackle all the jobs I did not want to do
Hi since I smashed up my beautiful Green 1995 300, I have been driving my older 300 most of the time being my only car, I had to take it off the road yesterday fo some major needed repairs.
Lucky I still have the use of my brothers 911, seeing he is still living in Hong Kong.
I am so embarrassed at how I have neglected my car, but only doing 1 - 2 thousand miles a year and having a bad back (no excuse really) it is now time to sort everything out before the next MOT.
Having sold most of the parts I had collected, I have been getting ready with the long list of parts I now need, how the prices have gone up, can’t really believe it.
Started stripping her down yesterday, what a mess.
The only good thing about so much oil leaking is those areas are rust free.
2004 BMW Z4 30i
1991 Nissan 300zx TT Project
1997 Jaguar XK8 Scraped ☹️
  • Replies 117
  • Views 9.4k
  • While I rest waiting for my trapped nerve to get better, I have been slowly cleaning my callipers, my friend Took them off for me.   I also received my new front number plate.
  • Not much has been done, my friend put petrol in his diesel Saturday ruining my day, I had to sort it for him. Pistons in all callipers now, I also started the engine ran it up to temperature all
  • Car passed mot and is now taxed and fully legal. ?‍♀️??
Ready for take off.
Most stuff disconnected, to my surprise exhaust bolts came off but it does not look like I needed them, they are not coming apart.
2004 BMW Z4 30i
Finally parts have arrived, but I’m sure I will find more that I need.
Built engine hoist yesterday.
Finally got the engine out, will start the strip down tomorrow, after a good clean up.
2004 BMW Z4 30i
Cheeky little ********
I was thinking great I have gotten away with it.
No play looks good
Then drivers side.
2004 BMW Z4 30i
Both sides stripped down, all nuts came off but not taking any chances, I have a new kit for manifolds and turbos.
Bit of a mess at the rear.
God did it rain today so glad I bought a heavy duty tarpaulin yesterday, no chance of getting engine stand out.
2004 BMW Z4 30i
[ATTACH=CONFIG]117983[/ATTACH][ATTACH=CONFIG]117984[/ATTACH]
[ATTACH=CONFIG]117985[/ATTACH]
[ATTACH=CONFIG]117986[/ATTACH]
Get a rear main seal in there and a new sump rubber.I always do both now at the same time.Quite often the rubber strip is like plastic and shrinks and no amount of sealer will stop it.
Be really careful with the engine say in its sump, it’s really easy to crush the pan a little and the clearance between the pan and pick up tube isn’t much at all. The subsequent oil starvation and pan exchange is a world of frustration you don’t want. Trust me.
Yes have all new from CPZ
2004 BMW Z4 30i
Thanks I will make sure I have not dented it.
2004 BMW Z4 30i
Can’t believe how time fly’s today was my first free day to get back to the car, built engine stand, then had to take my mums car for MOT, thank god it passed so I have some transport. Engine now on stand ready for oil pump change , rear crank seal then put everything back together with new gaskets.
2004 BMW Z4 30i
Wow!!....just read all 4 pages of this engine refresh.
Great work so far. Keep it up.
Looking forward to the next update :thumbup1:
Not bad I would say for an old girl.
2004 BMW Z4 30i
Just as I suspected and hoped, my front oil leak was from a crack in the pump casting, you could not tell from the outside but I knew what I had tried and just made more sense than the seal not being installed correctly, should have just cut the cog off instead of trying to pry it, lesson learned the hard way but that’s life.
2004 BMW Z4 30i
While I have been cleaning the sump and putting the oil pump and rear crank seal in, my dear friend has been cleaning the engine bay.
2004 BMW Z4 30i
Today I fitted the timing belt.
Back of engine tidied up EGR deleted, when the turbos are rebuilt I will be plumbing the water pipes directly to inlet-outlet pipes.
2004 BMW Z4 30i
i can see from other pics, it doesn't look like you have a pit in the garage, so this picture just looks so weird to me :lol:
nice to have some help though, and it's looking good :thumbup1:
[ATTACH=CONFIG]118503[/ATTACH]
I couldn’t resist taking that photo the car is about 5 inches from the ground at the mo will make it higher tomorrow.
Turbos cleaned ready for the new cartridges I did not want the hassle of taking them apart, just getting the casting off took 2hrs each.
Engine mostly back together new manifold studs.
2004 BMW Z4 30i
Still need a bit of cleaning but on the final stages now.
2004 BMW Z4 30i
New core? And new wastegate actuator?
Z1 upgraded OEM wastegates.
Garrett Turbo UPGRADE 360 Race bearing Pre balanced core and housing.
2004 BMW Z4 30i
After taking the turbos and pipes home this week and after a lot more cleaning, I finally got to my friends today to put them together, problem being I needed someone to hold the casing while inserting the circlip, it is so strong the pliers kept coming off.
The other turbo we put the circlip on but I had forgotten one of the bolts so only half done but the circlip was my main problem.
Tomorrow I will get the exhaust manifolds on and the rest of the pipe work sorted, ready for the final install (I hope).
I think the work involved rebuilding turbos, even with a new cartridge I found hard, the cleaning etc. I could not have afforded new turbos and have saved myself half the price of new standard ones, but if I had the option would not have put myself in a position of this much work.
2004 BMW Z4 30i
Tbh mate, that front circlip is the worst part, bar none. Rebuilding the CHRA is actually pretty straight forward and doesn’t take long.
This weekend I hoped to get both turbos on and adjust the suspension so the car is not 2inches from the ground.
Suspension adjusted being new was easy.
Turbos well the passenger side fitted fine
Drivers side just would not line up with the wastgate on, hitting the exhaust and that was that, scratching my head did not work either and kicking myself I left the old wastgate at home.
Well home and put the new and old together and the bracket is a sort of mirror image not the same. They are meant to be upgraded OEM got them from Z1.
At least I know now and can rectify the problem.
Looks like I need some core plugs will change a few.
2004 BMW Z4 30i
Finally back at the garage, renewing some of the core plugs, purchased a set but knew I was only going to change a few.
Last one will be done when it’s off the engine stand.
Edited by Bones28
2004 BMW Z4 30i
