Just thinking about a workaround for the common issue people have of the speed signal dissapearing causing interrupted PAS assistance (could be speedo cluster, converter, speed-sensor etc.); how can one go about stopping the speed-sensitive system. Even if it's something programmed within the ECU surely you can simply bypass the ecu and have a constant live on the pas pump?
ย
Anyone done this? I have GPS speedo I'm not really fussed on the needle working.
ย
