gearbox - auto or manual?? TT or NA?
Hi, everyone
I am a new member and just starting the journey towards hopefully owning a 300zx.(32)
So, please bear with me, if my questions seem somewhat basic!
I would appreciate some feed back on the merits of the manual and auto boxes. Is one more reliable than the other? Is there a real performance drop off, if you go the auto route? I would guess that the auto box is kinder to the whole transmission/rear suspension - correct?
Also, regarding the twin turbo or naturally aspirated.
Is the NA performance adequate? Are there differences in chassis cabin spec etc between the 2 models. Does the TT offer a better investment potential? Any advice would be welcome.
Thanks in advance
Ian
Welcome to the Club Ian. I had to lookup Ruyton X1 Towns on the map as I hadn't heard of the name before! You will get lots
of opinions on your questions from members re transmissions, NA/TTs and body types.
Generally speaking manual cars are preferred to automatics and are considered more valuable/desirable. Automatic boxes can
be unreliable (usually from abuse and/or poor maintenance) It is not uncommon for automatics to be converted to manuals with
donor parts from cars being broken.
There is a significant difference in performance between TT and NA cars. Most TT cars are also modified to leaser or greater degrees
to increase peformance which the cars respond well to. As it is so subjective your best bet is to get a drive in both types to help
you appreciate the difference (same for manual/auto comparison). TTs are generally considered the more desirable/sought after
of the two types.
The main difference in cabins is between the 2+0 (two seater) and 2+2 (four seater) types available in both TT and NA form. UK
spec cars are always 2+2 TTs. Imports can be either cabin type.
Hope this helps.
Edited by AndrewG
Spelling
Thanks for your advice, Andrew
Ian
TT manual is the desired choice and by far the most fun and exhilarating. Having driven every single drive train, I personally wouldn't entertain an NA, especially an NA Auto. If you're going to go for something with the looks and poise of the Z32, it has to have the drive train to match.
Welcome to the club!
.....don't write the NA off though. Read up on Slickpete's threads. He gets plenty of smiles and fun out of his modified track car!
Thanks, Funkysi
Ian
Cheers!
Ian
Welcome to the club Ian great advice from our guru's.
I have an auto TT & on my 3rd auto box! Having said this I like auto's!!
Thanks, Art
I, too, like autos!
Ian
Having had both auto and manual in the same car. If I had my chance again I would have an auto box uprated rather than a manual conversion.
I have a 2+2 targa TT, people will tell you they're a big heavy drag racer. They handle absolutely fine, or they can be made to handle well I should say. They might be heavy but they're plenty powerful to move the weight. The SWB cars can have less traction than the LWB.
Secondly, Manual conversions. Like mine, an OEM quality swap, there are differences in cams and turbos, but they are still very powerful engines. It is no compromise having the small turbos they're awesome.
Hi, Tom
Thanks for response.
Ian
I've said it before and I'll say it again having driven a TT zed first with auto and them being converted to maual. The manual makes realise just how much power you have got under your right foot, and perversely makes you realise just how good the auto box is at smoothing out the power delivery
Edited by TonyB
Interesting response, Tony
Ian
Can you explain what the uprating consists of?
Ian
