Hi guys
I’ve had a look through the FAQs, Techs and done a search but can’t find anything on door glass removal and refit. Has this been covered and could someone post a link please? If not I’ll try and make one myself. Any ideas how long it should take and if I’ll likely need to replace any clips etc?
Cheers,
Chris.
Take door card off, unbolt the door glass runner stoppers (2 of them), take the outside window trip off without bending it, unbolt the glass from the motor, 2 bolts, lift glass out.
(You have to take the outside and inside pillar trip off also)
Once the door card is off, replace the window switch, you'll need to lower the glass to near the bottom to enable access to remove the 2 x 10mm nuts (not bolts) Ali mentions.
