Best place to tap into the ignition live
Managed to find an ignition live on the ecu, just need to test for a permanent live connection.
I'm installing my own fuse box for accessories like gauges so a heavier gauge of wire connection point is better.
The connections on the ecu are much larger, I had this wired up on my old zed but can't mind how I did it.
Just a quick note: saw a fair few boost controllers use the radio / clock feed and subsequently had problems with the solenoid cycle / frequency as the feed supply is too small, be sure any supply feed is capable or running the new and old circuit at the same time.
Jeff
