Hi there
I am in urgent need of a Squib / slip ring to get my car through the mot. I ordered one on ebay which turned out to be wrong. I also visited a scrap yard today and removed a squib which was also the wrong one so went away empty handed. My car is a '95 'M' Non airbag
It must be the same as the one in the pictures of my old one
Please see pics
Price and P&P please if you can help
Many Thanks
Patrick
Hi there
Please see pics
Many Thanks
Patrick
To get through the mot just remove the warning lamp. This becomes a pass and advise then. Then repair properly in your own time.
Ok that is an air bag slip ring in the photo, guessing someone has changed the wheel for a non air bag so hence the light, also the light is actually a large led soldered to the track in the speedo so no bulb to remove, you could cover it.
Jeff
Sorry. Forgetting mine is a series 4 so does use a seperate bulb.
Jeff
No the steering is very much an old style non airbag one
The horn was not working because of the broken slip ring so mot fail
I never saw any warning light on the dashboard, that's not the problem
Did you get this sorted?
I am returning the wrong one on ebay and he has the correct one which I'm ordering, it's from banzai breakers in Farnborough
Ok good, I have a
partially broken NA so if you get stuck give me a shout:)
Ok good, I have a
Hi mate, well the new one I got is also wrong, its from a late model 98/99 by the looks of it, my car is a 95 and my friends which uses same squib is a 96 so its that era part I need. The garage are going to try and see if they can get it to fit somehow but if it wont ill be needing to find another one, what year is the NA your breaking ?
The breaker is a 1990/G non-turbo auto, does your one have a part number on it?
I have one of those off my 95 na, but as said that is an airbag wheel adapter (which mine was) , not sure if i broke it taking it out though, so will need to dig it out the garage
[sIGPIC][/sIGPIC]
Just a reminder Lee that Registered users can not sell on the forum. It has to be FOC.
Of course, was not looking to sell any parts, was just trying to help 300addict if he got stuck:)
No worries Lee and nice one mate.
:) I bought the Zed years ago and have used it as a parts bin and as a mobile garage to store Zed bits in!
You say broken slip ring causing horn not to work. These dont have slip rings, they have a coil of ribon cable
Here are some photos of the one i have. Note the top of mine lifts off allowing the coil of cable to jump out, cant remember if this is meant to happen and is held together in the car or because i broke it
Yours has less wires on one side, but you can always cut the spare ones off
[sIGPIC][/sIGPIC]
What yours does seem to have broken is the 2nd plastic peg, which i think is indicator cancelling ?
[sIGPIC][/sIGPIC]
  • 1 month later...
It's not for cancelling Ian, they're just steering wheel engagement lugs.
Hi even. Do you still have the n/a breaker I'm after the indicator cancelling ring for back of my stock wheel. It came without it
Paul
Paul
Hi Paul, yes still have it - I will have a chance to remove the steering wheel at some point in the next few days
