Constant Backfires and some spluttering on idle
So for the past few weeks the Z has been backfiring heavily when coming down the rev range in any gear - without being pushed at all (just shifting down a gear and leaving it come down on it own).
Recently i had the O2 sensors changed by Jimmer and some fresh turbos and it is more or less since then.
I have bought a brand new MAF from Z1 and just changed the spark plugs all-round.
Im also idling around 950 rpm, and can hear some break-up in the exhaust tone every few moments.
Any suggestions on what to check next?
91TT Btw.
I cant see any blatant marks, i am assuming it is ignition as there is a fuel smell
I have checked for ECU Codes but nothing to report - i should also add it is a JWT ECU, although it wasnt having the issue previously.
Unfortunately no conzult best i could do was ECU Codes
I will test the PTU thanks Ali
I am attempting to test my PTU following the continuity test but the diagrams aren’t matching..
Can I just take abcdefg as 123456E?
Thanks for confirming, not getting any continuity through it. Perhaps it’s dead..
