Drivers door glass
Well I told the guy from day one the drivers lock doesn’t work so the battery must not go flat the f..img **** has had car for 4mths and a mth ago battery was flat but nose panel was off so he called me and I got bonnet open he has run battery flat so much (new battery )don’t think it’s holding charge he lock it last fri and put outside I went today as it’s finished part from bonnet polishing and it was lock and couldn’t get it I get a call hour later from his mate saying he tried to get in and yes broken window what is it with this f..img car and arsehole garages he’s also blown immobiliser so alarm guy coming tonight hence need glass hi mate said he’ll get one I said good luck as rare found a new one in aus $245 plus shipping
For one you can unlock without smashing the window without key. Also why can you not unlock with the key?
Lock just spins always been like it never had problem as always in my garage with trickle charger on so alarm fob opens and locks
Good job your reverse gear works otherwise you might have got a smashed up front !
Sent from my SM-G955F using Tapatalk
