Free stuff - E/W finisher (driver side) + indicator stalk.
Have here a indicator stalk from a JDM model. Works perfectly and has no wear on the little telltail graphic.
Also a driver side electric window switch finisher. The often crack in the middle and the screw holes disintegrate. This one is in great shape. Missing the bit of carpet that goes inside the grab handle area, but other than that, it would make a great replacement for one that's broken or faded.
Stick them with the other bits mate. :thumbup: I’ll send over something via BACS again if you like. (Will the indicator stalk work with a UK car?)
They've already left my possession I'm afraid. I need to send you the tracking number for the parts.
Potentially I could drop them off super early on the 13th of next month as I'm catching a ferry from Newhaven and the drive will take me past Chichester.
The indicator stalk will fit your car but it won't be the correct one. The UK model has a main beam telltail decal on it too.
Thanks mate. I’m ok with that, drop off whenever it’s good for you. Don’t worry about digging up the tracking number, only need that IF there’s a problem.
As for the indicator I’m happy for someone else to take that as it’s not compatible with my car. No point in me hoarding parts that don’t fit my car.
“The UK model has a main beam telltail decal on it too.”
It'll still work. It's just a detail on the stalk. If you go and look at yours you'll see a main beam logo on it too. I have a UK one in mine and a UK hazard switch button which is also different.
