Electric windows not working
LOL guys here with another problem,my electric windows are not working on both sides,passanger and drivers(passanger and drivers switch,s do nothing)The only thing that happens is that on the drivers switch when i press up for the drivers window,the switch makes a noise,Is the switch screwed or would you guys know what the problem might be,Thanks all
Do your electric seats work? There is a fuse in the engine bay.
Yes my electric seats work mate,could it be the switch
also there is 12v power goin to 3 of the pin connectors
The window controller? Small black plastic rectangle box with conector on end, in frivers door
[sIGPIC][/sIGPIC]
Here are the power supply routing, junction/fuse box (showing ignition relay location) and power window diagrams:
el-10-11-1.pdf
FOLDOUT.pdf
bf-11.pdf
The power window amp only controls driver's side window. Seperate circuit paths for driver and passenger
window motors. Check the 15A fuse shown in the diagram (junction/fuse box - EPS/HICAS) located in the
drivers footwell. The ignition relay also controls the power window circuit. This is often damaged by water
leaks from targa drain.
Guys thanks for replying,I think it was the window controller as when I gave the the door a bang beside the box the windows started working:punk:
99% chance it will happen again sounds like a dry joint in that power unit. Take the opportunity to take the door card off while you can open the window it's so much easier
