How to check if relays are working?
Hi guys i have sorted out the issue with the damp in the car(targa pipe pulled out on drivers side)At the fuse box, but i have a brown relay and a blue relay and i dont know if they are working,can i use a battery charger or multimeter to check if they are bad,any info would be great.Thanks guys and gals
also where is the best place to buy relays in Europe,uk or ireland
You can check them with a fused +12v source (battery) and a multimeter set to continuity testing. These
pages from the FSM show the standard relays, their functions and connections:
el-5-6.pdf
Before you buy any of them ask on here first as you may be able to get working s/h ones. Their
part#'s should be printed/stamped on the upper body of the relay.
