Is it normal for zeds to lose track of the steering angle if the steering wheel is moved without without the ignition on?
I spent some time getting the sensor and steering wheel all set correctly a few days ago only to find today that the steering angle displayed on datascan is out again. The only thing that I could think I had done was moved the car with no battery on so I set it right again. I then noticed that moving the steering wheel without the ignition on caused the angle to go out again...part of me thinks this can't be right but having had the sensor apart I can't see how it could keep track of the angle when there is no power to it as all the slots in the disc are the same size apart from the large one used as the neutral position sensor?
Can anyone confirm if their car does the same?
No posts to show
