Think the starter motor's on its way out.
For a while now, it's been making a slight noise after starting. Like the teeth haven't disengaged the fly wheel properly for a fraction of a second.
But tonight, it's started getting worse. Twice now I've tried to start it and I've just received a grinding noise and no turning of the engine. Only on the second attempt does it work. Which probably means that in a day or two it won't start at all!
Anyone care to render an opinion on the problem? And also, does anyone know the price of a new starter?
Mike
check your bolts are tight mine did it one of the bolt had striped it's thread if it's not that i have a starter somewere
rod
Sounds ominous.
New ones are an arm and a leg, so you could always buy a second hand one off me.
Let me know if it does end up being the starter at fault.
Andy (01634 221783 or geewhizz@onetel.net.uk)
the starter on ours does that sometimes, makes an aweful grinding noise, yesterday it made a different noise, it was cranking the engine nicely then BANG, I thought :eek: , but tried it again and started a treat :confused:
My starter motor went last year but wasn't that at first, a dud battery gives the same symtoms so checK that first!
My local auto-electrician is pretty good and managed to replace just the necessary components inside the motor which saved me some of the green stuff.
James.
I had exactly the same problem.
Apparently its the caused by a worn ring gear (the bit on the flywheel which the starter strikes against).
Mine's been a pain in the arse for about 12 months - cos its a clutch out job to get to it I've just left it , but I'm finally getting it done at the same time as my rebuild.
