First thread; WHAT INJECTORS ARE THESE (370cc or 550cc? or...?), please help. Thanks.
hi Guys and gals
I hope all is well.
I really need help on figuring out what cc this injector is, the part number on the top is;
2M50 9925N 4
the numbers below the rubber seal are a46 -00
its greeny brown
it doesn't have a dot on the top like some sites suggest, which suggests it is a 370, however I saw an image of the same one on another site and the bloke said it was a 550cc >
fbid=10160317766175393&set=a.10160317765970393.1073741876.556520392&type=3&theater
here are other images that look like it (on the bottom of this page its the dark green/ brown one next to the dark red one);
https://z32.wikispaces.com/Fuel+Injector?responseToken=0f9d8954e415e447b28e06791e351de5b this site suggest it is a 370cc and seems believable.
Below is is the site that conflicts with others about the CC (about half way down he states they are old nismo 550cc injectors, of which I don't believe as mine are the old original ones and look exactly the same);
https://www.gizmodo.com.au/2017/03/heres-exactly-what-it-cost-to-buy-and-rebuild-a-nissan-300zx-twin-turbo/
I would put a pic up but that doesn't seem simple on here.
again thanks for your help.
Gaz.
p.s any new driver door key
This picture link on wikispace you mentioned shows a red non turbo injector of 270 cc next to a dark green / brown twin turbo one of 370 cc your own link picture does not work.
Jeff
Hi Jeff, thank you for your response and I apologise the links don't work I copied them directly from the URL field.
with the details I gave with the part numbers on mine can you advise if my injector which looks very much like the TT one in your pictures above is the 370cc injector, as some pages say its a 550cc.
thank you.
Gaz.
This is the image you're getting confused about:
I would say its very unlikely that yours are 550cc injectors.
hi Andrew and Alic
thanks for letting me know, you are right the ones that conflict are the ones you poste dup on here, the browny green ones the phase one type pintel, I have disgarded the red ones as I can easily see those.
so, I it is likely the 370cc not the 550, I was hoping that as its the bit I got which actually looks like the image above, I had one delivered from America and the 370cc jecs ones look like the above dark purple ones but a lighter purple.
thank you for your input, is there any where that will confirm the cc size with the part numbers I put above as I want to know for 100%?
thanks all
gaz.
