Clutch booster
To clean up bay .
Clutch booster is fitted behind the clutch pedal inside the car, not under the bonnet, if you meant the brake booster do not even bother trying to remove that.. end of.
Jeff
What are the black plastic tanks under the wings in front of the A-post?
The 'air boxes' for the AIV system I believe.
I know the ones you mean but not those. These are only accessible by taking the wing off
The plastic box seen below (turquoise) is an air canister that supplies the aiv system that's under the guards.
Ah right, my mistake. I thought the AIV ones were the ones behind the arch liner each side
They are, but those units behind the liner are fed by this box.
There is a small plastic tank in the wing near the one in your photo ( but i dont think its that one) that is connected to the clutch booster. Its to do with keeping constant clutch pressure when the vacuum level might otherwise fluctuate
[sIGPIC][/sIGPIC]
