Top fuel dragster facts (from TT net)
Some interesting Top Fuel dragster facts:
* One dragster's 500-inch Hemi makes more horsepower then the first 8 rows at Daytona
* Under full throttle, a dragster engine consumes 1 1/2 gallons of
nitro per second, the same rate of fuel consumption as a fully loaded 747
but with 4 times the energy volume.
* The supercharger takes more power to drive then a stock hemi makes.
* Even with nearly 3000 CFM of air being rammed in by the supercharger on overdrive, the fuel mixture is compressed into nearly-solid form before ignition. Cylinders run on the verge of hydraulic lock.
* Dual magnetos apply 44 amps to each spark plug. This is the output
of an arc welder in each cylinder.
* At stoichiometric (exact) 1.7:1 air/fuel mixture (for nitro), the
flame front of nitromethane measures 7050 degrees F.
* Nitromethane burns yellow. The spectacular white flame seen above the stacks at night is raw burning hydrogen, dissociated from atmospheric water vapor by the searing exhaust gases.
* Spark plug electrodes are totally consumed during a pass. After 1/2 way, the engine is dieseling from compression-plus the glow of exhaust valves at 1400 degrees F. The engine can only be shut down by cutting of it's fuel flow.
* If spark momentarily fails early in the run, unburned nitro builds
up in those cylinders and then explodes with a force that can blow
cylinder heads off the block in pieces or blow the block in half.
* Dragsters twist the crank (torsionally) so far (20 degrees in the
big end of the track) that sometimes cam lobes are ground offset from front to rear to re-phase the valve timing somewhere closer to synchronization with the pistons.
* To exceed 300mph in 4.5 seconds dragsters must accelerate at an average of over 4G's. But in reaching 200 mph well before 1/2 track, launch acceleration is closer to 8G's.
* If all the equipment is paid off, the crew worked for free, and for
once NOTHING BLOWS UP, each run costs $1000.00 per second.
* Dragsters reach over 300 miles per hour before you have read this sentence.
i think you'll find that should be 14.7:1 !
some interesting facts tho :)
I love it when they burn out and you can see the tyres wind up so to speak.
For petrol yes, but not for nitro as nitro methane is contains lots of oxygen so is it's own oxidiser.
Quote from...
http://216.239.39.100/search?q=cache:MwjFjzbSeTcC:pages.prodigy.net/csw_cmt/page10.htm+stoichiometric++nitro&hl=en&ie=UTF-8
"...Nitromethane does contain a lot of oxygen, which makes it nearly a mono-propellant. Meaning, it requires almost no additional air (oxygen) for burning. Therefore it burns best when run at a very rich ratio of 2:1 to 1:1! Thus even though pound for pound nitro is less powerful than gasoline, nitro can make almost double the power of a gasoline engine of the same configuration..."
