Do wheels from other manufacturers fit the 300, or is it just specialy ordered stuff???
not too used too site yet just done search n found some int stuff hmmm
Really virtually any 5 stud alloy will fit but its best to get the offset right.
Stuart
There are a lot of different Pitch Circle Diameters (PCDs - the distance apart which the holes are). Some can be REALLY close but would be lethal if fitted. Do be careful.
Dave
You need the correct offset, PCD (stud spacing as Dave said) and centre bore.
The Z has a PCD of 5 x 114.3mm, and I believe the centre bore is 60.5mm.
The offset you want will actually vary depending on how wide the wheel is you want to fit, but there is a rough guide at http://www.twinturbo.net/ttnetfaq/FAQpages/rims.html.
Alternatively, someone knowledgable about aftermarket Z parts will be able to advise you well - Luke at the Z Centre perhaps (http://www.zcentre.co.uk)
