protoj · Tuesday at 18:48 1 day
Hello there!
I was looking to bore and to lace the valve's on the header cams, wondered or a doner could be found from another model or if there is anyone who sells such a kit in the UK?
Many thanks!!
bore and to REPlace the valve's (sorry!)
Maybe I should say bore out a furather 2 mm and replace the valves to fit.
