Manual gearbox prop and slave
Hi all
After a manual tt gearbox , prop and slave
Cheap as possible please ??
I don't have either for sale, but it might help folks if you're able to tell them whether yours is a SWB or LWB (different length prop shafts).
I'd be inclined to look for the best you can rather than the 'cheapest'.
Its actually for a conversion that im playing around with.presume lwb would be better as i can always cut the prop if needed.
I wouldn't recommend that unless you know what you're doing. The props are finely balanced and unless you weld in a jig and then have the facility to balance them, I'd avoid doing that. NA differentials also have a different flange at the back. I don't know the complexities of what parts you need as I've always had a manual TT, but worth asking on the tech section although you probably know all this anyway.
Edited by Funkysi
Oh not planning on doing it myself.work in progress for another car its a tt im looking for for the strength as will be pushing 400hp
